denon 3500x hdmi monitor 2 out question (1 Viewer)
Tibornagy
Tibor nagy
So i have have everything running thru the avr using the arc out channel from avr the arc in channel on the tv. The one problem is the arc in channel of the tv doesn't support uhd deep color. This is primarly only a issue for my 4k samsung bluray. The hdmi 1 port on tv does support uhd, could i run the blue ray to avr and monitor 2 out to hdmi 1 on the tv? I read the entire manual and couldn't find much about monitor 2 out.
Adam Gregorich
What to watch tonight?
The Other Washington
Adam
Yes you can. This is a good way to still use ARC and support your 4K player. You may have to enable monitor 2 out in the settings of your AVR. If needed, it would be under the HDMI options.
JohnRice
Bounded In a Nutshell
A Mile High
My question is, are you even using ARC to begin with? If not, the solution is prpetty simple.
Feetman
