Jay H
What is the best method to cut carpet, to avoid as much freyed edges as possible? I know to cut rope and cords use for climbing and stuff, they use a hot knife. Probably not feasible for carpet use. Simple utility knife? tips?
I have to cut out a section of my hallway that meets the rear door so I can lay down some bluestone or slate or tile depending on the clearance I measure.
What should I use for the border too, a simple wood trim cut to length? I don't think I would use a saddle in this application.. In the process of trying to find authentic Catskills bluestone...
Jay
Jay
