- Feb 8, 1999
- Robert Harris
I'm going to do my best here not to fall into various potential traps in reviewing WB's new 4k UHD release of Mr. Friedkin's The Exorcist.
There have been numerous variants of the film created for the past half century, with changes to color timing, effects, audio platforms, et al.
AFAIK, there are no true reference prints, although there should be a timed IP, that might be helpful toward finding the original color scheme, if that is what WB and the filmmakers desired to reproduce.
Therefore, this review will be based upon a single attribute. That being, how will this disc be perceived by virgin viewers, with no previous knowledge of the film and it's various incarnations.
And for those viewers, aside from what I consider to be a horrid cover design, the film should hold up beautifully.
Color and densities "work," as do black levels and shadow detail, although they may not be accurate to the original release. Grain looks proper for Eastman 5254.
Both cuts are included, with the extended using an Atmos track. The original logo has been replaced with something special - not certain if it's new to this releases. I've not researched.
The Atmos track is proscenium filling and works beautifully. One might presume that it's derived from the 1979 70mm release, but one shouldn't presume anything with this project, I shall follow that tenet.
Image – 5 (HDR)
Audio – 5 (Dolby Atmos)
Pass / Fail – Pass
Makes use of and works well in 4k - 7
Upgrade from Blu-ray - Definitely
Worth your attention - 10
Slipcover rating - 2
Very Highly Recommended
RAH
Image – 5 (HDR)
Pass / Fail – Pass
RAH
