Hi all, seeking your advice!
I connected a new Denon AV receiver with 2 HDMI outs to:
(I used brand new HDMI 2.1 cables to connect)
To fix this without using the trial and error-mode I would like to learn he following:
- A TV (full HD - no 4K)
- A 4K-60Hz beamer through a 4K -60HZ capable HDMI extender. (to another room)
- Will there also be issues if I connect A 4K - 120Hz TV instead of the Full HD one, and keep the rest the same (4K - 60Hz)
- Is there a way to fix this using the same 2 output screens?
- but use a different receiver / or brand of receiver who's capable of dealing with this (which one you recommend on a budget?)
- If I add a HDMI splitter at the HDMI out of the receiver, can this fix the problems?
