AV Receiver turns off when I switch to Blu-Ray HDMI port (1 Viewer)
Curt Gilker
This is a new development, as I have not changed anything in my setup for several years. Today, when I switched to the Blu-Ray player (using HDMI), the receiver turns off. this happens repeatedly. The other HDMI ports and inputs work fine (i.e. Roku, TV).
It is definitely the Blu-Ray player, as I changed it to another HDMI port and the same thing happened on the new HDMI port. Similarly, I switched to another HDMI cable, and the receiver still shut down.
Any ideas on how to troubleshoot further? Or just get a new Blu-Ray player?
Thanks in advance.
Clinton McClure
Rocket Science Department
Central Arkansas
Clint
Just a thought but it sounds like the Blu-ray player may be overloading the receiver and possibly causing the thermal protection circuit to kick in.
Can you turn the receiver back on after it shuts off and get a Blu-ray to play or does it shut off every time?
JQuintana
BANNED
Me
As silly as it sounds, may want to unplug power to both for a minute. The plug back in and test.
Curt Gilker
My thought too, but I don't know why this would just start now (but I am no expert). And yes, the receiver shuts off every time.
John Dirk
ATL
JOHN
Thanks in advance.
Sounds like a Consumer Electronics Control [CEC] issue to me. Check the Blu Ray players settings. Different companies may use different names but its basically a protocol that allows basic commands to be sent via HDMI to other capable devices. When you find it, disable it.
unbob
