Brian L
- Jul 8, 1998
Anyone check this out???
http://homepage.ntlworld.com/john.mu...meq/index.html
And there is an AVS thread talking about it here:
http://www.avsforum.com/avs-vb/showt...hreadid=529224
I have not actually tried to use it, but I did load it and fired it up, and am going through the documentation as we speak. If I am reading this right, this software, after taking room measurements, will actually identify the peaks, and then calculate the required BFD filters for you.
Judging from the literature, it seems to be pretty easy to use, which hopefully will translate to a short learning curve.
This looks to be way cool if it works as it appears it will.
BGL
BGL
