World Wide Stereo
Buying projector & screen (1 Viewer)
lipets
Bob
I have a optima HD25E, for last 6 years works good
Now doing new home, want a 10' wide ceiling drop screen, lots to pick from
the room is 14' wide and 28' long | Ceiling height is 10'
Screen Sugestions?
I know the HD25 had set focal length if about 15' due to room depth
Now with this long room how far from the screen do I calculate distance to ceiling mount?
want to prewire electric in ceiling
What projectors should be on my short list?
Non gaming
Dave Upton
Audiophile
Houston, TX
Dave Upton
Bob,
Do you have a budget in mind? You're looking for a 138" screen, so that will cost you about $1000 give or take, depending on your goals. A fixed frame screen would be superior, but I assume that won't work in this case.
Will the room be fully light controlled? Do you primarily watch movies or TV, and how important are black levels?
Wayne_j
Wayne
Screen Sugestions?
Non gaming
This site will do the calculations for you:
lipets
Bob
Bob,
$1,000 is about right, there will be some light in the evening but the fully controlled
Not sure about black levels or what that means???
movies/TV about 60% TV
Gemini007
