Cleaning out the HT closet-Tweaker'sSale (1 Viewer)
Ron Boster
I've a mix of items for sale for those who have wanted to tweak their system's at a reasonable price...
Bright Star Audio's
AIR MASS 3 pneumatic mount ™ 17.25"x14"x2" 8 lbs., ship wt 10 lbs.
Single air cell, holds up to 99 lbs. Optional hand pump. Fits under Big Rock 3 and 4. Formerly Air Mass 1.
This item works perfectly, but has minor flaws from a cosmetic standpoint...nothing that would turn you off.
Shipped for $80 (includes the $15 air pump)
Tice Solo Video Power Conditioner:
The Solo VPC (Video Power Conditioner) is a multi-function Video specific power conditioner. Video equipment is particularly sensitive to dirty A.C. power causing washed out colors and flat grainy two dimensional images. Install a Solo Video Power Conditioner and be prepared for uncompromising video performance with brilliant high resolution images, deep detailed blacks and enhanced color fidelity. The VPC will significantly reduce power line noise while it stands guard protecting your equipment from damaging spikes and surges. The VPC operates on three levels simultaneously to move you steps closer to the quality of High Definition TV. The results are simply amazing!
http://www.ticeaudio.com/frm_pcmi.htm
Shipped for $300
Harmonic Tech. Pro-AC 11 Power Cord
The Pro-AC11 is constructed with the finest high purity copper. Two shields UL/CL-3 are used for superior RFI rejection and fire protection. They are available with a variety of IEC female and male plugs. Kalman Rubinson has recommended this power cord in Stereophile's November 2000 issue.
Using the finest 6N (99.9997%) high purity copper in the world, combined with Single Crystal TM (OCC) design, the Pro-AC11 will make an astonishing difference in your system. Using the technology of our Pro-11 Plus speaker cable, two additional shields are added for rejection of RFI, digital, and other electromagnetic pollution. Since the purity of the musical or video signal can be greatly affected by the component’s power supply, it makes perfect engineering sense to provide your power supply with electricity which has been conditioned by the Single Crystal purity of the Pro-AC11. This power cord eliminates and rejects RFI due to shielded construction, using both a foil shield and a separate braided shield to drain away any unwanted electrical interference. Since the electricity fed to the component is now free of electrical disturbance, including collision with crystalline barriers and impurities, the power supply of the component can now allow the musical or video signal to be processed without additional distortion being added.
This power cord has been selected by manufacturers and famous magazine reviewers and can be recommended for the finest systems.
Two 1.5 Meter Power Cords: $110 (each) shipped in the lower 48 states.
Couple of other products:
Dalite Tripod Stand (used for two weeks-went to a ceiling mount with a 5 yr old in the room).
http://www.projector.com/kore/catalo...8/product.html
Shipped for $75
Cheif Adjustable Extension Column:
Chief adjustable extension column extensions can be used with any NPT 1 1/2 in. coupler to lower projector to desired height. Provides 6" range of height adjustment in 1" increments depending on model. (18 - 24 in. lengths)
http://www.projector.com/kore/catalo...4/product.html
Shipped for $80
Email me at [email protected] or call me at home/816-822-1701.
Thanks for looking
Ron Boster
Ron Boster
New Prices:
Air Mass + pump. $69 delivered
Harmonic Tech Pro-AC11 Power Cords: $95 each/delivered
OR, $170 for both delivered
Chief Adjustable Column: $69 delivered
mycuu
