RobertSiegel
- Mar 10, 2004
I am ready to finally buy a screen (with a limited budget) and have found the Elite M150UWH screen (150" diag....75 x 130 viewing area) for only 199.95 on Projector.com. Has anyone else purchased a screen in this price range or from the same group of screens (they make all sizes in the M-UW MODEL THIS WAS THE BIGGEST)., which is all I can afford. Right now I am using a 4 x 8 poster board, so this would be an additional 4 feet diag in size, a great size for my wall. It's a manual pulldown screen: Any info would be appreciated (unfortunately there are no gray tinted screens anywhere near this price so it's the best I can afford).
Viewing Area 75” x 130”
Diagonal Measurement 150"
Screen Format HDTV(16:9)
Screen Fabric Matte White
Gain Gain 1.1
Screen Case Color Black
Warrenty 1 year
Dual Wall and Ceiling Mount Design
Advance Auto - Level - Lock - Lock on Any Position and Easy Operation From Floor Level
Special Black Masking Borders - Increases Picutre Focus Point
Matte White Screens - Easy to Clean and Durable for Daily Usage
High Effective Scattered Screen Angle (>100 degree) - See Cear Picutre From Different Angles
Flame Retardant Property meets CPA-84 Standard - Extra Safety Protection
Gain Gain 1.1
Warrenty 1 year
