sillymarmoset
- Aug 21, 2009
- John Scott
Hello,
This is my first posting so here goes!
Since I have a 4K/3D LG TV, & 4K native blu ray (PanasonicDMP-UB900) player I decided to change my HD projector to a 4K one Optoma UHD51. I also decided to purchase another 4K native blu ray (Sony UBP-X700) player just for using with the new projector. My AV Receiver is a Pioneer SC-1224. These model numbers might be different to those in the US as I live in the UK! Then the horrors of the so called 4K certified HDMI cable connections - at first the Sony 4k player would not work with the Optoma - although I tested it on the 4K input of the 4K TV using the same cable and it worked! So I then swapped it round with the Panasonic 4K player and connected it to the projector using the SAME new 4K cable and it worked! OK so with this pairing all is well for watching my HDR blu rays (and 3D) on the projector and TV. On my previous setup the HD projector had two HDMI inputs which allowed me to also watch live TV and recordings via my panasonic HD recorder - no problems. The new 4K/3D projector also has two HDMI inputs so I connected my HD recorder using the second 4K HDMI cable (same make as the one used for the blu ray player) there is quite a bit of motion blur in the image. I then tried a none 4K cable connection and the same thing with the image? The recorder works very well when connected direct to the TV. Is the image problem because the panasonic recorder and projector are not compatible? I would rather not purchase another HD recorder which is 4K just to watch live and recorded TV on the big screen. Any suggestions? Sorry to have written such a long post - hope you have not fallen asleep!
