Help me upgrade (AV Receiver, Sub/s, and advice) (1 Viewer)
CalebC
Grip
I currently have the following gear:
  • JBL Arena F27 and the JBL Arena C25; still the old Atlantic Technology 171 surround speakers.
  • Subwoofer: TIME to UPGRADE (I had atl tech 172 which kids ruined and a crappy free hand down JBL has a hold me over until I was ready to upgrade, which is now)
  • Receiver: TIME to UPGRADE (Denon E300 AVR just died)
  • Pioneer Elite 141FD Monitor (it's still kicking and hard to replace but will be replaced someday soon--no giant rush bc its calibrated and still phenomenal but I know the tech is passing it up)
  • of course Xbox and Bluray
  • i do also use appletv standalone for a lot of viewing and music.
Budget is $1500 - 2500.
Room is large: 15 by 20 feet and 15 foot vaulted ceilings. Its open and leads to another room behind it. Viewing is about 10-12 feet from screen and speakers with surrounds about 8 feet high and 12 inches behind viewing.
As you can see it is a very modest setup (I'm a teacher after all)..i have 2k-ish to spend on Sub/s and a Receiver.
I am having a tough time finding a receiver that is a good fit--any and all suggestions are welcomed--I really miss my first big purchase Integra receiver long ago but the Denon had seemed good enough.
For subs I'm aware of svs, hsu, and outlaw subwoofers but no idea really what I really should look to do (get 2 in the range of PB1000s now and call it a day or get 1xPB2000 range and look to expand on it later).
Any and all help is welcomed
Lord Dalek
Joel Henderson
If you got money to burn and a big room, you might as well go all in on Atmos.
JohnRice
Bounded In a Nutshell
A Mile High
So… you’re asking about sub(s) and a receiver at $2,500 or less.
Just clarifying.
John Dirk
ATL
JOHN
The room will be your biggest limiting factor and practically rules out Atmos. I'm admittedly biased but I believe SVS offers the best overall performance vs value combination so I'd go with the largest single sub [minimum PB3000] you can afford for now and grab it's twin when funds are available. Not a great time to buy new AVR's so I'd be looking at previously owned options.
JohnRice
A Mile High
Also, I've become a real sealed sub convert, having moved from all ported to all sealed models.
Where SVS is concerned, don't think model line vs model line. Think price, because any given ported model is usually almost the same price, if not the exact same price as the sealed model in the next line up. For instance, the PB-2000 is the same price as the SB-3000. In that case, I'll take the SB-3000 every time. The step from 1000 to 2000 is $100 more, 3000 to 4000 is $200, but that's a big jump in performance, and the price difference between PB-4000 and SB-16 is $0. In every single case, I'd take the higher sealed model, but that's just me.
ManW_TheUncool
His Own Fool
The BK
ManW
Yeah, that 15ft vaulted ceiling... unless one's willing to do some additional reno work perhaps to allow the ceiling speakers to be installed much lower like 8-9ft...
Anyway, a $1500-2500 budget doesn't indicate having "money to burn"...
_Man_
mycuu
