xx Brian xx
- Dec 18, 2017
- Brian
After buying a new house, I had a dilemma. I wanted a projector and screen for movies but do not have a spare room for a theater room. My wife and I didn't want all kinds of electronics in the living room this time either.
The solution took a lot of work but came out better than we expected. I did everything myself including all programming of whole home automation, installing all components/parts and pulling wires through the attic and walls.
Hope you enjoy the pics.
Step one was installing all components in a smart closet. I control the temp in the closet with a thermostat from CoolerGuys that will kick in fans to bring cool air in at the bottom and blow warm out at the top of the room. I modified two cheap shelves from local hardware store to hold all components. I ran a 2" pvc pipe through the wall from the attic for current and future wires. I also have a separate smart area just for the network. Everything in the home is hardwired through a 16 port switch. Components are fully protected with two Panamax surge protectors.
There are 28 speakers throughout the whole house with separate volume controls in each room or they can be controlled through our phones. I use three separate multi zone receivers to feed all the zones. I already had the receivers and didn't want to spend more money on a matrix switch. There is no reason to know how they are connected to operate the system because I programmed Control4 to operate everything seamlessly. You just select what you want in each zone and Control4 will do the rest.
The solution in the living room for a screen took only a few days. I installed an Elite Screens power drop screen and hid it behind a hand built decorative board. I ran a Hue LED light strip to make it look like that is all it is for.
The screen is operated from the 12v trigger on the receiver when it switches to output 2. The way it works is: When I tell Alexa to "Turn on home theater" she send the command to Control4 and the Control4 turns off the TV, turns the 4 overhead lights dark blue, switches receiver to output 2 (which in turn triggers the screen to drop), turns on Epson projector, sets volume to 42 on receiver and then after 15 seconds turns off the front two lights and dims the rear lights to 20%.
Equipement includes:
Sony XBR65X930D
Marantz SR 7010 for main room
Yamaha Aventage RX-A1030 for multi zones
Sony receiver for multi zones
Sony UBP-X800 Bluray
Apple TV
Roku 4K
Raspberry Pi running Kodi
Epson Home Cinema 3700 projector
All speakers are Klipsh including the 4 ceiling speakers. I run a 5.2.4 system which I like better then when I ran it as 7.2.2
Control4 programed with Amazon Echo for full voice control.
Let me know what you think. I hope to be helpful for others that are working on their own projects.
Brian
Sony XBR65X930D
Apple TV
Roku 4K
Brian
