Christ Reynolds
- May 6, 2002
- CJ
i have my pc connected to my pioneer vsx-45tx receiver through rca cables, using the cd input, and it sounds like shit, i was wondering if i could use a toslink cable, but they are across the room. i also used the usb input, and i wasnt satisfied with the sound with that either. plus i hear that if you use the usb input, it limits the amount of digital inputs you can use or something, i dont exactly remember. anyway, does anyone know of a toslink cable that is in excess of 12 feet or so? i'm not sure of the limitations of the toslink specification, maybe thats why i cant find a cable longer than the 10 foot one at bettercables. any help is appreciated, thanks
CJ
CJ
