rivrbyte
- Feb 10, 2013
- Jim
Need help with OTA antennas, and running through a surround system. Cutting ties with cable!
QUESTION:
Is there a way to hook up Over the Air (OTA) Antennas, into a receiver, to get surround sound?
Hello!
I need to DRASTICALLY cut ties with TIME WARNER, and DO NOT want any long-term contracts, with early termination fees, with any of the satellite companies.
At present, I am with Time Warner, on their "Triple Play" year promotion, that ends next Friday. This plan gave me 200Mbps, Nation wide long-distance to Canada, US, and Mexico, Caller ID, Epix for one year, and basic/broadcast cable channels. No Sports, no pay per view. I usually watch Nat Geo, SyFy, CNN, MSNBC, local stations, Discovery, and also listen to the Music Choice stations, and that's about it, I don't need 5,000 stations.
My SET UP ~
I have two TV's, one is in the main Family room, with a Yamaha 7.1 Surround receiver, connected to a Samsung Smart TV. T/W goes into receiver, then out to TV.
My other TV, in the master bedroom, is not very 'Smart", and is a seven year old, HDMI compliant, Samsung, hooked to an Apple TV, for streaming Netflix.
My PHONE ~
The phone is needed, on my landline to enable me, to send and receive all too important faxes to and from my doctors, and I will not go to Kinko's for this service, if I can help it.
My DEVICES ~
I have an Ipod Touch 5th GEN., and a desktop PC.
An Epson Wi-fi WF 2660 All in one printer.
LOCATION ~
I live in a hilly area, of Southern California, and I don't have good AM/FM reception. So if I do go with a roof top antenna, would I be looking for UHF,TV, with FM? My local stations are about 50 miles away to Los Angeles. I have a 35' sound wall about 50' feet away, for the train, and also wondered if I would need to install this on a higher mask, (over this wall height) or I would be set-back far enough of an angle, to have an unobstructed line of sight for a strong reception.
ANTENNAS ~
After seeing those infomercials on the portable HDMI Digital receivers that you attach to a window, then into your HDMI TV, how would I run this through my surround sound? I saw a "Channel Master". $10.00...Is this a joke? I called best Buy, and he told me about a 'Ultatenna', from Channel master Model # 4221HD. Best buy Sku # 339-5396. $65.00. Up to 65 Mile range. multi-directional. (14-69 stations)
I am on a very low disability with a rare terminal metastatic tumor cancer and can no longer afford the "luxury" of having cable, as expensive as it is, and only continues to climb, but now, I'm scrambling to find a cheap internet and phone plan.
I thought about ATT and Direct TV, but not sure about their 'come-on' offers of $19.99 (SELECT) per month for first year, then the second year contract is far more expensive, then if you terminate, you owe $15 or so, per month, until the contract has been satisfied.
If anyone at all knows what I am trying to achieve, and can recommend a decent, not too expensive antenna, to be able to run this through my surround system, and also a way to set up my second TV, with this same connection, but without surround, that would make me happy!
So, in closing, is OTA the way to go, or is this far more trouble for me, than it sounds? All I know is, I think I would be happy with only a phone (no contract) and Internet capability, to stream Netflix, and to continue to use my ipod, and desktop PC, as well.
Thank You!
QUESTION:
Hello!
My SET UP ~
My PHONE ~
My DEVICES ~
LOCATION ~
ANTENNAS ~
Thank You!
