Hello everyone.
I have recently acquired a little older AVR Marantz NR1602. It should be able to do DD Audio which for me is what i need, as i wanted only a little better upgrade from my Logitech Z906, in terms of speakers.
I have hooked it up to my LG B2 with HDMI cable but i cant get it right whatever i do. On TV is plugged on HDMI Arc port (HDMI3) and on AVR on ARC HDMI (i guess the only port meant for Tv? )
AVR i habe set up from scratch doin factory reset and then with setup wizard. It is all quite straight up and not much i could ve done wrong.
Bit it seems sound simply dont get right. If i set on TV PCM then it works but apparently it is only Stereo and AVR cant do much. If i do Pass through which is logical and let AVR do processing i get extreme sound stuttering regardless of sound source, being just TV lame stereo or Netflix 5.1 makes no difference.
Now i got to mention to a tv i have also hooked up Xiaomi android box which i use occasionally.
Then i have tried with optical cable and have changed the setting in AVR settings as well.
Now i get sound regardless of my options only sometimes when i get to Netflix (apparently Netflix recognizes if you have 5.1 requirements) on TV shows 5.1 or if i change to PCM shows no 5.1. on the other hand on Netflix on Xiaomi shows Space Sound and instead of 5.1 shows Dolbi Atmos possible.
Regardless of all that when it is set on Auto on reciever recognize only Stereo. Which i need then manually change to PL2 or DTS Cinema which i dont think thats it…
What am i missing?
What am i missing?
