vinny-Eire
- Dec 6, 2020
- Vinny
Hi everyone well the receiver i bought 20 years ago hasnt been working so well lately so i went out and bought a system off a friend of mine , 20 years ago since i set up my system so i am very rusty with all this new modern systems, plenty of advice will be needed
First of all i will list what i have that i can use
Yamaha RX-V575 AV Receiver
Cambridge Audio SX120 Subwoofer
Cambridge Audio S50 Centre Speaker
Cambridge Audio S20 Stand Mount Speakers (One set 2 speakers)
Cambridge Audio SX50 Stand Mount Speakers (One set 2 speakers)
Bose Interaudio 2000xl Book Shelf Speakers (One set 2 speakers)
LG Network BLU RAY Disc Player (Model BD370)
LG 42 Inch Full HD 1080P LCD TV (Model LD450)
A little dated but hopefully will do the job for me ,
So my yamaha is 7.1 or 7.2 its hard to figure out and what i need to know is which speakers should i use for front speakers , Surround Speakers, or how exactly does 7.1 or 7.2 work how many speakers should i have
On the rear of the yamaha the speaker ports are Front, Centre, Surround, Surround back / bi amp / zone b (All same one)
So thats whats confusing me what speakers go where.
Then the subwoofer preout on the amp has two ports labeled 1 & 2 , but the subwoofer itself only has one so which should i connect to
Then the Bose speakers are they even suitable to connect up to the amp the specs of them are as follows
SPECS: INTERAUDIO 2000:
CABINET SIZE....9"W X 14"H X 71/2"D
WOOFER SIZE....6"
TWEETER SIZE...3"
OHMS.....4 to 8
WATTAGE.....10 to 70W MAX
Next question , the room was prewired for rear speakers but the wires are not marked so i dont know which one is + and which is - is their a way of finding out this or if i connect wrong way around will they do damage
Thanks every one for reading this and would be very grateful for any suggestions on the set up thats ahead of me
vinny
WOOFER SIZE....6"
TWEETER SIZE...3"
OHMS.....4 to 8
vinny
