World Wide Stereo
Monoprice 15 V2 Sub with Onkyo TX-RZ50. What Cable? (1 Viewer)
sbradfor
Shannon Bradford
I just bought a Monoprice 15 V2 subwoofer that I want to connect to my Onkyo TX-RZ50. What cable would people recommend? I"ll probably need to run it 20 to 30 feet. It has what are called LFE and Line unbalanced inputs (1 & 2). I'm not sure what type of cables to use for these.
Thank you in advance for any help and advice.
JohnRice
Bounded In a Nutshell
A Mile High
Just any sturdy RCA cable is fine. Monoprice doesn't seem to have one channel models anymore, but plenty of others are available. Your receiver doesn't have balanced outputs, so you just use a single cable like THIS from the subwoofer output on the receiver to the LFE input on the sub.
sbradfor
Shannon Bradford
Perfect. Thanks so much, JohnRice. That is what I thought. You confirmed what I figured it was.
hilogisticz
