andySu
- Apr 7, 2006
Denon AVR-X8500H Dolby Atmos with some modifications.
DOLBY STEREO CP200 cinema processor perhaps best one made for 70mm THX approved
Duel Sony SDDS DFP-D3000
x4 DCX2496 DSP crossover management
Lucasfilm Ltd THX sound system crossover monitor
Panasonic 900 THX and 9000 THX UHD 4k
HD-DVD
bluray
LASERDISC AC-3 dts
JBL five screen channels and this was before the projection screen was fitted up with x6 JBL subs
120" fixed acoustical transparent screen with JAWS 3 region 1 playing in Dolby Stereo, video projector viewsonic 727 4k pixel shift DLP.
Viewsonic 727 4k pixel shift HDR DLP
x9 overhead surround Atmos. I call it AtmosPlusIIIx as I'm extending the basic use of it for better immersive with extra channels for each of the Height 1, 2 and 3 channels that are on the floor. wow sounds great
x132 JBL speakers at 21kw
Minor repairs to the Dolby CP200 cat cards cat109c meter filter cards with brand new meters that are same as found in a CB radio that I have and had to import the meters from USA and with some assistance from Dolby labs to get the CP200 back up and running as it only needed few basic repairs of the good condition it was in.
Also the meters I wired them up so they can be illuminated as all previous ones I seen in UK cinemas never seemed to have the meters lit up. The terminal pins are on the meters and it was case of finding 12v supply on the card with a resistor soldered in place to lower the voltage.
Swapped the labels around and painted the needle red.
One of the second JBL 4682 TCB placed at back of the room to even out smooth sub bass along with JBL 4645 4645C and extends down to 10Hz after EQ and turning and testing.
Dolby cat109c meters lit up maybe first time with this CP200 since it was made. The CP200 was released around March 1980 and was discontinued around late 1990's, while service and parts was still around until early 2000's.
Between soldering the new alterations to cat109c my cat Magic wants some meaty sticks.
x6 sub bass shakers and below surround that is matrix from sidewall channels so that some actual pans do pass underneath the seating for a better Dolby Atmos that has below middle and height dimension.
HD-DVD
bluray
LASERDISC AC-3 dts
