greggor
- Jan 6, 1999
- Greg
I'm having an issue with my Harmony Elite and Hub. Our internet router stopped working and needed to be replaced. After connecting the new router and getting back online I noticed that the light on the Harmony hub is red. I went into the app on my computer and followed the wizard for setting up the hub and for some reason the software won't find it. If I connect the remote via the supplied USB cable my computer doesn't seem to detect it. The remote works but I'm not able sync or make changes. Any ideas?
I have also tried resetting the hub using both the reset button on the back and doing a hard reset by unplugging it and then plugging it back in.
