World Wide Stereo
New to Surround Sound, Help me with my setup! (1 Viewer)
kevin82287
kevin
Hello everyone,   I'd love to get some help setting up my new equipment. I recently purchased a Sony STR-DA2400ES receiver and my plan was to hookup my existing Logitech Z-5500 subwoofer and speakers to the receiver. I also have two Pioneer SH253BK speakers that I might consider using for my two front speakers.   My question to you all is, can I hook up the Z-5500 subwoofer to this receiver? I've read a few different threads (including here http://www.avsforum.com/avs-vb/showthread.php?t=1134243) and it looks like a few people have been successful. I'm still confused on what connections I would use to hook it up though. I am on a pretty tight budget and if someone could help me accomplish this, I would really appreciate it!   I should also mention that I am living in a condo middle unit (but with only 1 neighbor). The unit has an 8" concrete firewall between my neightbor and I also put extra insulation on the common wall where my entertainment system is going to be. I read about Dynamic Range Compression and this seems like something that would be good to keep the sound levels consistent. I plan on throwing some rubber pads underneath my subwoofer to help mitigate vibrations as well.   Devices: - Sony STR-DA2400ES receiver - Time Warner Cable Box - PS3     If anyone has any other tips, comments, or questions I'd love to hear them. Thanks for your help!   KevinHello everyone,
Devices:
- PS3
Devices:
- PS3
Kevin
elwaylite
Jason
Try this one. Seems to have better instructions for the sub, that worked
http://www.avsforum.com/avs-vb/showthread.php?t=1017630
kevin82287
kevin
Sorry, I don't think I was fully clear. I understand that I could use the Logitech controller to hook it up to the receiver but I have an extra set of the speakers without a controller. So I'd like to hook the subwoofer directly into the receiver.
adityalbarrett
