Onkyo TX-NR646 home theater system (1 Viewer)
martinp
Martin Potgieter
I am having problems with my 7.1 channels. I am aware that when you do use as "Zone 2", 2 of the back channels namely left and right back won't work as those 2channels get used as zone 2 so effectively you get reduced to a 5.1. now when I stop using zone 2 it should return to a 7.1 which it does sometimes. If I do a speaker check, at times not all the 7 channels work and some don't work. Has anybody else experienced this? The other day only the centre and the front right were working and all the others were off. I then activated and deactivate zone 2 and then the picture changes and if I am lucky all will work some other work as well.
Regards
Martin
+27834884053
[email protected]
softwinsystems82
