never-enough
- Apr 8, 2020
- tom
Just set it up & I noticed all 3 presets for the equalizer are all flat across the board. DO folks normally just leave it alone or adjust manually? If you adjust, what are your settings? It's a 7.1 system w/1 sub.
Also, when playing music from my thumb drive via the rear USB port, I noticed that I can only randomize the play of songs in 1 folder at a time. Is there a way to set it to play all songs on the entire drive in random order?
