World Wide Stereo
Outdoor Audio for Backyard with a Pool (1 Viewer)
utahband
Roger
I'm trying to plan a wired 2-4 zone outdoor audio setup. I'd like to have a receiver in the house with wifi control with Alexa (via phone). In a couple of weeks I'll be pouring concrete in the backyard and I want to make sure I have all of the conduit/buried cables taken care of ahead of time.
A couple of questions that some of you with experience might be able to answer:
1. I've purchases from 2 wire, 14 gauge direct burial wire. Is that suitable for runs of +100 ft?
2. Are the guidelines for daisy chaining speakers within a zone?
3. I'm planning on going with mono speakers outdoor speakers.
4. I'm open to suggestions for all equipment: speakers, multi zone amps, receiver, wire.
Below is a generic schematic of the backyard layout (assuming 8-10 speakers): https://i.imgur.com/GNptRNU.jpg
What are you looking for (Speakers, Subwoofer or Both)? Speakers, outdoor sub(s)
Primary Use: 99% Music, 1% TV & Movies
Desired Configuration: Not sure
Room Size: 75x55
Is the room open to other areas of your home: No
Do you already have an AV receiver or amplifier? No
What's your budget (low to high): $1500-2000
Any special requirements (Wife Acceptance)? Optional AppleTv/ChromeCast support for outdoor zones
Adam Gregorich
What to watch tonight?
The Other Washington
Adam
Sorry for the delay. Are you planning on using mono speakers or dual tweeter speakers (essentially a L+R in one speaker). Asking because the DT models require two runs of speaker wire or 14/4.
I would put everything in conduit since it will be under concrete- if there is ever a problem you can easily re-run it.
Depending on what you plan on playing, I would use Sonos Amps instead of a receiver. They play nice with Alexa and Google and have a great phone app.
Will you have a TV in the cabana, or anywhere else outside and if so do you want the audio from that to be played on a zone?
Other than that I don't see you really having different things playing at the same time, I'm assuming that the zones are more for volume control reasons?
hilogisticz
