Wouter Bovelander
- Oct 10, 2017
- Wouter Bovelander
Hi,
I have an 18 year old VSX-908RDS-G which I want to connect to my PC, the ultimate goal being able to connect my SpeedLink Medusa 5.1 surround headset to the amplifier. I've managed to connect everything, but I only get sound through the Front Left and Front Right channels. I would like to find out if the solution I've thought of actually has a chance of working. It's this amplifier's last chance at a useful life and I really want to make it work.
I've connected my PC's outputs (3 x 3,5mm jack connectors for Front Left/Front Right, Side Left/Side Right, Center/SubWoofer) to the amplifier's External Decoder In inputs. Naturally I've used converters to convert the three 3,5mm jacks to six RCA plugs.
Next, I've connected my SpeedLink Medusa's three inputs (FL/FR, SL/SR, C/SW) to the PreOut outputs of the amplifier, again using RCA to 3,5mm jack converters.
When I set the amplifier's input selector to the External Decoder, I only get output on the FL/FR speakers and on none of the others.
Does anyone have a clue as to why this is happening? Is the External Decoder In actually looped through to the PreOut outputs? Is there perhaps a setting I should change in the amplifier?
Thanks!
Wouter
Thanks!
Wouter
