Question on how to turn an ordinary 2 panel switch into a BRILLIANT one (1 Viewer)
So, this is what I am ASSUMING is called a 2-panel switch?
This switch controls a ceiling fan (left) and my fluorescent kitchen light fixture (right)
I'd like to know if it's feasible that I can switch this out for this:
A few questions go along with that...
1. Can I turn an old ceiling fan into a smart ceiling fan with speed control and voice commands with this Brilliant Switch?
2. I know Fluorescent lights cannot be dimmed (I think that is what I read), but can a switch like this turn them on and off with voice commands?
Are switches like these easy to install? I am basically just swapping out wires from the existing fixture?
Thanks in advance
Mysto
Florida
marv long
Thanks in advance
I don't know about how it will work for you but in the reviews there was this. The fan is a no-go.
4.0 out of 5 stars Does Everything You Think and Hope it Should, Except...
Reviewed in the United States on September 3, 2022
Size: 2-Switch PanelVerified Purchase
...Except for fan-speed control. On/off only - For that I subtracted a star. Other than that they thought of nearly everything. High WAF too.
DaveF
Catfisch Cinema
Dave
I replaced a number of switches with Lutron Caseta switches. They can be controlled with the physical buttons, with Siri, and with HomeKit, among others. I have automations to turns lights off at night, to dim them for TV watching etc.
Lutron Caseta Smart Switch Starter Kit | Compatible with Alexa, Apple HomeKit, and the Google Assistant | P-BDG-PKG1WS | White https://a.co/d/9p6UCew
Lutron Caséta Smart Home Dimmer Switch and Pico Remote Kit, Works with Alexa, Apple HomeKit, Ring, Google Assistant (Smart Hub Required) | P-PKG1WB-WH | White https://a.co/d/51t5K8p
mycuu
