So I have had some speed issues with my JVC QL-50 where the turntable where the quartz lock would fail and the turntable would speed up to around 45 speed when set for 33. Now the speed is almost constantly speeding up and slowing down. And then goes into full on speed up mode! I also have an issue with the cartridge and have to crank the receiver to get half way decent volume and I end up getting ruble feedback. To make sure this was not an issue with the phono section of my Pioneer Elite SC-05. I unplugged the turntable and moved it to another room where I hooked it up to my older Yamaha RX-V995 with the same result but the Yamaha is hooked up to a pair of Polk bookself speakers and a 10" sub under a heavy desk. So I am waiting for a reply from a place that works on turntables to see what price range the speed issue could cost me and to see what regular maintenance would run. Then I am looking into the cost of a new cartridge and am looking at ether a Grado or Ortofon.
So just wondering if this turntable is even worth putting money into? It would be expensive to buy a new turntable and am looking into the following. And I say expensive because I am stuck working part time and really bad wages, hopefully that will change by the end of the year. Don't think I want anything that offers a USB connection!
Turntable List: (New & Used)
Onkyo CP-1050 Direct Drive Turntable $399.99 (Best Buy)
Marantz TT-15S1 Belt Drive Turntable $1,499.99 (Best Buy)
Thorens TD-170-1 Turntable comes with an Ortofon OMB10 phono cartridge. (Needle Doctor)
Denon DP-57L Turntable (Ebay)
Vintage Thorens TD-115 Turntable
Pioneer PL-5L Direct Drive Turntable
Sansui SR-929 Direct Drive Turntable ????
Dual CS 460 Belt Drive (Made In Germany 2013)
Music Hall MMF-2.3
Project 1Xpression Carbon Turntable
Clearaudio Champion Turntable
Any suggestions, nothing over $1800 max. I can not justify anything over that and besides I want and need to save up for a new receiver, leaning towards a Marantz SR-7010.
A local record shop has a clean Dual Turntable that looks like it is from the late 70's for $300. I am not interested in anything from Stanton, Numark, Reloop, Teac or Gemini. No DJ turntables!
Other System: Polk 10" sub is under the desk
Music Hall MMF-2.3
