Bobby C
- Dec 23, 2003
Hi,
I've run in-wall 14 ga. speaker wire for the fronts, center, surround & rears (a 7.1 system). The surrounds & rears will be on wall, so I think I'll just drill a hole in wall and directly connect the wire to the speakers. However for the front & center, I'm thinking that I don't want the in-wall speaker wire to connect directly as the speakers will be a couple of feet from the wall & the wire is white.
So I'm thinking that for these speakers I want to terminate the in-wall wire at a plate with a binding post. Then I'll use terminated speaker wire from the post to the speaker. However I've never done this type of work before & have some questions:
1. If the in-wall is 14 ga., should I match the wall to speaker wire?
2. Is attaching the in-wall wire to a binding post require specific tools? Any on-line guides to this process?
3. For the in-wall wire that I'm going to run directly to the surrounds and rear, is it recommended that I terminate the wire with spades, banana plugs or just leave the wire bare? Again, special tools required if plugs or spades?
Bob
Bob
