World Wide Stereo
Thoughts on this budget "4k" TCL TV? (1 Viewer)
Alf S
BANNED
Alfer
We aren't looking to spend a bunch of money on a new 55"-60" HDTV and I found this TV for about $400 at Wal Mart. We already have 3 Roku TV's in our bedrooms (TCL, Insignia, Sharp) and like how easy it is to use them, how easy it is to access streaming apps etc. since we cut the cable of DTV (literally).
So what are the pro/con's of grabbing this TV? Note that we have no plans to upgrade from Blu-Ray and aren't diehard cinephiles (sp) so having the best of the best isn't a necessity. We just want a decent upgrade from our 2012 1080P 55" TV.
TCL ROKU TV: http://www.tclusa.com/currentmodels/55us57/
Thanks for any input you can offer.
728x90
Alf S
BANNED
Alfer
Forgot to add that another + for this set is it actually has a TV tuner built in.
Alf S
BANNED
Alfer
Well we pulled the trigger last week on this set and have been very happy with it. Picture quality is outstanding as are all the features. I highly recommend it to anyone on a budget if you can find one still in stock.
hilogisticz
