This probably has to do with HDMI handshakes - I regularly cannot get an image on my screen when turning on the following components. The system will always play audio from the Oppo, but "No Signal" shows on the video processor display. I've taken turns in what order I turn components on, and occasionally (maybe 1 out of 20 tries) this order works:
1) Oppo BDP-95
2) Faroudja by Meridian DVP 1080MF
3) Onkyo TX NR-3008
Sometimes I just turn the Onkyo on and off (waiting 1 minute between) multiple times and system "catches". All connections are HDMI 2.0.
Is there a standard order I should be turning components on so they synch up properly and I get an image through from the Oppo to the projector attached to the Faroudja image processor?
Bob
1) Oppo BDP-95
3) Onkyo TX NR-3008
Bob
