Have a few questions in mind, thought to check with experts herein.
What i have:
- ROOM DIMENSIONS (effective): 26ft x 11ft
- FIXED SCREEN IN FRONT
- IN WALL SPEAKERS (FOR FRONT ONLY)
1) SPEAKER CONFIG
a)7.2 OR 9.2?
**Note: Since we have longer length, i could only think of 9.2 as an ideal option to assist sound travel. But must it be executed. I am looking at picking AVRs from Denon/Yamaha. Possibly adding a Marantz processor & a multi-ch Paradigm Poweramp later in a month or so.
2) HEIGHT OF SPEAKERS
a) what should be height of front speakers
b) what should be the height of surrounds wrt Row1 & Row2 (14inch higher)
c) Can the height for surround speakers be same for both Row1 & Row2 - I guess not, so kept the height 9inch higher for the second elevated row.
3) SCREEN ASPECT RATIO
Since I have too less a width to spare, I was looking at 16:9. Should be ideal for best experience, given the room's width constraint. What do you suggest?
Am assuming that 2.35 ratio wont go as the projected image shall come way too tiny cause of the lack of width, which shall further reduce with screen borders coming into place.
Thanks for your help on these. Once addressed, shall add different set of questions in next topic.
What i have:
1) SPEAKER CONFIG
a)7.2 OR 9.2?
