World Wide Stereo
Add a 3rd sub. or get two larger ones? (1 Viewer)
Craig Ball
I have 2 SVS PB-1000 subs in my HT (living room) its about 5200sq ft. I have a budget of 2k. Now i could add another PB-1000 and a mini DSP2x4 or retirn the subs I have and go with 2 PB-2000 Pro subs. Advice and opinions welcome.
David Norman
Man, either I hope you mean cu. ft, 500 sq ft, or may I formally request to be adopted as adult.
DaveF
Catfisch Cinema
Dave
Two larger subs. Or one enormous sub. If budget allows.
Since most room correction systems only support x.x.2 for two subs, adding a third sub I think will be non-optimal.
John Dirk
ATL
JOHN
If those are your choices then definitely go for the 2000's. Ideally, for a room that size I'd recommend dual SB16's.
JohnRice
Bounded In a Nutshell
A Mile High
The dual PB-2000s are definitely the better option. However, as John Dirk said, you will not achieve "chest slam" without spending significantly more.
To be honest, "chest slam" is overrated and ally a sign of an excessively hot setup.
As far as size, the SB-16 isn't really any larger than a PB-2000. Budget wise, of course, they are far apart.
Wayne_j
Wayne
He did mention getting a minidsp which he could use to dial in the three subs.
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
Im not getting that chest slam that i would like.
Chest slam comes from bass frequencies an octave or more higher than what is typically generated in an action movie. If your current sub set-up is otherwise performing satisfactorily and isn’t maxed out, save your money.
Wayne A. Pflughaupt
Phoneman66
