Add powered subwoofer as second subwoofer to existing PC / Logitech Z906 setup? (1 Viewer)
United Kingdom
Elliot
My setup:
The SW-150 is sitting in storage doing nothing, so I was hoping I could add it as a second subwoofer to my PC.
The Logitech system takes up all three of the audio jacks on the motherboard, so I don't think I'll be able to add the SW-150 without getting a soundcard with more jacks but assuming I did do that, do you think it's possible to have the Z906 and SW-150 working simultaneously?
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
Websites for so-designated computer speaker systems are maddingly void of connections information.
Bottom line, if the system has a line-level cable input specifically for the subwoofer (read, not a speaker cable), then an appropriate splitter can be used to get the signal to a second subwoofer.
Wayne A. Pflughaupt
Ontocloud9
