EricSchulz
- Jan 6, 2004
What do you recommend for the best protection? I'm looking for something that will cover my Mac, iPhone and iPad if possible.
Personally I don't recommend an active antivirus for Mac or iOS. I installed ClamXav on my MacBook Pro when I bought it several years back and have only run it a handful of times to check an installer package for malware before installing it. Back in my Windows days, a good antivirus program was worth its weight in gold but since abonding Windows for Mac I haven't seen the need for one. That was one of the many reasons I switched. If you're smart about what you do, OS X and iOS are pretty safe and secure on their own. If you feel you need a yearly bloatware package, Avast, Symantec and Sophos say they make good ones.
