JohnnyM
- Oct 6, 2001
My 20 year old Paradigm PS-1000 amplifier is shot. Speaker is good and was just rebuilt. Can I use one of my old amps to power it? If so, how would I get the LFE information from the source device into the separate amp? And if the separate amp does not have an LFE output, how would I get the signal to the speaker? I plan on simply attaching to the red and black wires of the sub speaker. I had a LFE cable running from my HT Receiver to the sub with a Y splitter. Would I need to cut that wire to reveal the 2 leads? Of could I attach the 2 speaker wires to the sub amp input and attach the red and white there? If it's possible, please answer these...
1. How to get the LFE signal from the source into the separate amp?
2. How to get the LFE signal from the separate amp into the speaker?
Other thoughts... my DVD player has an HDMI output and an optical output. Is it possible to connect the HDMI to the HT receiver and the optical out to the separate amp to provide the LFE signal.
I'm hoping to use an old Denon HT receiver (without HDMI but with LFE out) or an old JVC Integrated amp with neither HDMI or LFE out. Both amps are well over 100 watts/channel. The Paradigm was 250 watts. I'm hoping there's enough power for that 10" woofer.
