door whore
- Oct 12, 2019
- Dennis
Does two 24 AWG wires twisted together equal to the equivalent of one 12 AWG wire, to run for speaker cable?
Not even close.Does two 24 AWG wires twisted together equal to the equivalent of one 12 AWG wire, to run for speaker cable?
Banana plugs will not do anything for audio quality, but they are a great convenience when connecting the speaker cable to your receiver and speakers. Especially the receiver with its tightly spaced binding posts. I use banana plugs for all my speaker connections.12 Guage AWG Audio Cord - it will be stranded wire. If your system supports it, I'd also put banana plugs on each end for the connections.
Yes, I know. Like you, I use them for convenience. Not that I am constantly disconnecting/reconnecting the equipment, it's just easier to put banana plugs on the wires and plug them in instead of wrapping the wire around posts/screws and tightening the screws. If you do that you really should tin the wires with solder to help prevent them splaying when connectors/screws are tightened. It's usually easier to put banana plugs on the wires.Banana plugs will not do anything for audio quality, but they are a great convenience when connecting the speaker cable to your receiver and speakers. Especially the receiver with its tightly spaced binding posts. I use banana plugs for all my speaker connections.
