World Wide Stereo
Dedicated HT, speaker suggestions (1 Viewer)
rvspinx
Rob Clendenin
I have a pretty big dedicated home theater in my basement (at least it seems pretty large to me) that I am working on as time/budget allows. I have already purchased and installed the projector - Epson 5040UB and next on the list will be speakers.
Unfortunately the builder put all speaker pre-wiring in the ceiling so I am stuck with either attempting to run new wiring, build false walls, or find the best in-ceiling options I can. I was looking at Definitive Technologies RCS II speakers but not sure if there is something better that I have been unable to find on the google. I have seen these on sale occasionally for $400 a speaker which is about what I'm willing to spend (sub $3k for all 7 if I can).
For reference the room is 25x35x9. Including some pictures of the projector if it helps. (I will be capping that dome light btw)
I have no screen yet, I have to decide how I want to handle that as well.
JohnRice
Bounded In a Nutshell
A Mile High
I have one suggestion. Just do NOT use in-ceiling speakers. At least not with the front three. Find another solution. Snake wires from where they are in the ceiling and into the front wall, on the front wall, anything other than in-ceiling speakers. In-ceiling surrounds are at least acceptable, but not in the front.
Grimly
Brian
Chane speakers get a lot of good reviews at a different forum I go to, they have a free shipping option but the charge for a retune if I remember right, SVS also has a good rep for there speakers an very good customer service. RSL speakers have free shipping and returns also I have never heard them but I have seen good reviews of there speakers. Ascend Acoustics also has some nice options for that price but shipping cost both ways, at a very reduced cost though. There are a lot of options for a $400 dollar speaker. best in my opinion to try the ones with free returns first or a least low cost returns so that you can find a speaker set you like.
Grimly
Brian
Also check out the Kef Q100 and Q300 they can be bought at amazon so if you have a prime account I don't think they would mind returning them if you don't like them.
rvspinx
Rob Clendenin
So I have decided to use the pre-existing in ceiling locations as atmos drops and will instead run speaker cable through some crown molding and do in wall instead. That will also allow me to install some LED strips for ambiance lighting as well.
JohnRice
A Mile High
Why do you want to eliminate 98% of the speakers available by limiting yourself to in-wall ones? If you're going to all this trouble, why cripple yourself?
rvspinx
Rob Clendenin
Hmm.. it just seemed like it would be a "cleaner" install, at least aesthetically to use in walls. So I guess on-walls now in the mix. Luckily I haven't done anything else yet with the exception of building an inwall cabinet for my components so all the real equipment is still to be decided.
RobertTheBob
SVS Outlet Sale
