FS: Behringer EP2000 and Fi Audio IB 318 (1 Viewer)
kdoswald
kevin
Bought these to setup a IB but never got around to doing it and now need the money more then sub.
Everything is brand new in the box.
Each sub box ways weighs 40lbs. They are strapped together so can combine shipping if both our purchased.
Asking $220 per sub.
Asking $175 for the Amp.
IB 318 sub specs:
The IB3 Series of subwoofers is our higher power handling infinite baffle subwoofer line. Featuring a large high grade magnet with a heavily bumped T-yoke for clearance under high excursion. Along with single high excursion progressive spider, a multiplayer foam surround attached to a fiber impregnated kraft pulp cone helps keep things under control. A 3″ 2 or 4 layer voice coil yields 30mm of Xmax while keeping moving mass low. The IB3 sets the standard for full featured infinite baffle specific subwoofers. From the subtle nuances of a stand up bass, to the bottom octave filling rattling scene in your favorite movie, the IB3 has you covered.
  • Single 2 Ohm
  • Cast basket
  • Wrap around gasket
  • Kraft pulp fiber reinforced cone
  • Single layer wide foam surround
  • Push terminals
  • Extra heavy lead wire
  • FEA optimized motor
  • 3” diameter coil
  • Single high grade magnet
  • Single progressive spiders
  • Rear Tri-Cool System
Behringer EP2000
    • Behringer EP2000 Stereo Power Amplifier 2000 Watts
      Protected by an impact resistant, all-steel 2U rackmount chassis, the Behringer EP2000 Stereo Power Amplifier comes with ATR (Accelerated Transient Response) Technology.
      The EP2000 delivers precise power, signal and clip LEDs to monitor performance. For reliable operation, independent DC and thermal overload protection on each channel, a back-to-front ventilation system, high-current toroidal transformer and power transistors have been added. With rugged construction and high-quality components, this amp ensures a long life of amazing sound.
      Features:
    • 2 x 1,000 Watts into 2 Ohms; 2 x 750 Watts into 4 Ohms; 2,000 Watts into 4 Ohms (bridge mode)
    • Precise Power, Signal and Clip LEDs to monitor performance
    • XLR and 1/4 inch TRS input connectors for compatibility with any source
    • Professional speaker connectors and touch-proof binding posts support most speaker wiring systems
    • Selectable low-frequency filters (30 Hz or 50 Hz) remove distracting infra-sound frequencies
    • Independent limiters per channel offer reliable protection against overload and distortion
    • High
    • current toroidal transformer for ultra
    • high transient response and absolute reliability
    • Ultra
    • reliable Toshiba/Fairchild power transistors
    • Independent DC and thermal overload protection on each channel automatically protects amplifier and speakers without shutting down the show
    • Back-to-front ventilation system including air filter for reliable operation
    • Built-like-a-tank, impact-resistant, all-steel 2U rackmount chassis
    • High-quality components and exceptionally rugged construction ensure long life
    • Conceived and designed by Behringer Germany
Pay actual shipping costs, unless local to Los Angeles you can pick up.
bipbop13
