scotty74
- Nov 23, 2012
- Scott
hi all, new member here - hanging my new Samsung LED and here is my issue;
unfortunately i went the cheap route on the mount, walmart. great reviews, basic mount. should be ok.
problem is, samsung led's require a spacer as the screw holes are setback from what would be the flat back end.
so the hardware included with the mount has 2 sets that "should" fit. but, one is too short, and the other is too long.
now, the longer 8m40 has an included external spacer, now when that is used, its too short!
(deep breath)
now i can get about 1 turn into the tv when using the longer screws, but that scares me, i want those screws to go all the way, about 4 1/2 turns...
thoughts?
can i go to lowes or depot and buy a 8m screw that is slightly longer, 1/4 to 1/2 inch longer and if so, will this do the trick?
thanks for any help guys...
Scott
(deep breath)
thoughts?
Scott
