MrMorgan
- Apr 17, 2020
- Erik
Hi all,
I am having low volume issues with my hand-me-down Harman Kardon SB 16 subwoofer. It doesn't produce an acceptable volume level as compared to the soundbar.
I have to turn the volume knob all the way up to get nearly an acceptable volume. The quality of the sound is good, it doesn't sound weird at all, but I know it should sound a lot louder (especially for its monster size).
I'm using the optical cable from my Xbox One S straight to the soundbar.
What I've tried so far:
Can anybody help? Thank you.
- Moving it close to the soundbar
- Moving it in the corner of the room
- Trying all the wireless channels
- Plugging it in straight to the wall
- Smacking it and shaking it around (to see if something might be loose)
