sbjork
- Aug 1, 2020
- Stephen
While it would be lovely if HDR was a set-and-forget, one-size fits all proposition, we all know that simply isn't the case. Thanks to variances in how different displays are manufactured, there's no consistency in how they implement HDR, and results can vary wildly. One frequent complaint is that a given UHD looks too dark when watching in HDR mode, or even after converting HDR to SDR. While it's true that some HDR grades really do seem dim compared to standard Blu-ray, in other cases, it's really the display itself that's at fault. When a display tone maps the content of the disc to match its own peak brightness level, it may do so by darkening the image to compensate for its own inability to display the actual peak brightness of the disc. So, the HDR version will look darker on that display, but that's not the fault of the disc.
Even the best possible tone mapping solution isn't perfect. JVC's frame-by-frame tone mapping is the best in the business, but it's still not set-and-forget. I have a calibrated RS2000, and while the tone mapping works for most discs without needing adjustment, occasionally something does look too dark. That's why JVC offers different mapping levels. Sometimes, I have to adjust it to "High" to compensate. (There's a "Low" setting as well, but I've never needed to use that.)
If there's any complaint about HDR in a thread regarding specific title on UHD, it's often about the disc looking too dark. Trying to solve that problem usually involves drilling down into questions about the specific display, source, and settings involved, so it may sidetrack the thread a bit. So, if a given disc looks too dim on your display, post any questions about that over here instead of in the other threads. This is your new home for HDR-related frustrations, and hopefully another member will have some suggestions for you. To quote Harry Tuttle, we're all in it together.
