kalm_traveler
Hey guys this is probably something I should have looked into years ago but I'm only just now running into a situation where I'm happy with my AVR (Yamaha RX-A3080) but want to add 2 speakers more than it can push.
It can only drive 9 channels at once, and the room is set up as 7.1.2 with 2 forward ceiling atmos speakers. I'd like to add 2 more atmos speakers behind the sitting position but I'm not sure how to do that as I'd rather not buy an 11 channel amp just for this.
Is there some kind of 2-channel amp setup I can get that will be fed a correct signal from the AVR for those rear atmos speakers? Also, if so what's the easiest way to make sure they're balanced with the rest of the system?
Thanks in advance!
Thanks in advance!
