World Wide Stereo
How to disable SVM on Samsung HCN473W? (1 Viewer)
Jeff Cooper
Little Elm, TX
Jeff Cooper
Sorry if this has been covered before, but the search function is not working for me at the moment.
A friend of mine just purchased a new Samsung HCN473W widescreen RPTV for $999.99 at Fry's. I am working on getting it calibrated and need to know how to disable SVM on this model.
So far the picture also looks very grainy, but I have heard that Samsungs are very dirty inside and need a good cleaning, so hopefully this will clear up that issue. But I really need to know how to get rid of the Scan Velocity Modulation! Thanks for any info.
WebsterM
With TV off, press Mute 1 8 2 power seqentially to enter the service menu. Select 'Video Adjust 2' and then set VM Level to '0'.
At least this is how it is done on an Samsung HCP4752W.
adityalbarrett
