World Wide Stereo
HTPC connect to DAC for Home Cinema (1 Viewer)
Dario1971
dario rosario
Hi all.
I have to connect an HTPC to a Yamaha RX-A3080, in order to view my movies.
Because HTPC it is 20 meters away from Yamaha RX-A3080, how many ways you know I can use?
Thanks in advanced.
Peter Apruzzese
Peter Apruzzese
The distance is why an Active cable is suggested, normal HDMI cables are good for only 5-10m or so.
DaveF
Catfisch Cinema
Dave
Hi all.
Thanks in advanced.
You've got four solutions:
Standard HDMI
Active HDMI as suggested by @Peter Apruzzese
HDMI by CAT
Use a streaming device (AppleTV, Roku, Nvidia Shield) with wifi running HTPC client app to connect to an HTPC server app, and not run any wiring.
hilogisticz
