World Wide Stereo
Is it possible to Re-purpose old speakers? (1 Viewer)
Angelmartin11
Martin Gomez
Hi, i recently found a couple of old speakers lying around in my house and I was thinking i could maybe use them with my tv, the tv is a samsung nu7100. The thing is the speakers have a weird connection, it seems like its just two cables (a red and a black one). Is there some kind of adapter or is it even possible to use them with the tv?
Btw im a noob when it comes to this topic :huh:
JohnRice
Bounded In a Nutshell
A Mile High
That's not a weird connection at all. They're just regular speakers that connect to a regular receiver/amplifier. There's two steps to get from the TV to being able to use the speakers. You need to decode the digital optical output from the TV, and then amplify it, with a volume control. There are a lot of ways to get there, but the simplest I find after a short search is something like THIS. You probably want something with a remote control, since the remote for the TV will no longer control the volume, but you can get away a lot cheaper if you're OK not to have remote volume control.
BTW, it's possible you can get away with just a simple amp, if the TV has a remote controlled, analog audio output. Unfortunately, none is mentioned in the TV's specs, and most TVs these days don't have that anymore.
Angelmartin11
Martin Gomez
If i buy this i will have to buy new cables? or can i buy the plugs and add them to the cables attached to the speakers?
BobO'Link
Mid-South
Howie
Just put the appropriate connector on the end of the existing cables. Normally red is "hot" and black is "ground" but it really doesn't matter as long as both cables are wired and connected to the speakers identically.
JohnRice
A Mile High
You'll need a toslink optical cable to connect between the TV and the amp. Otherwise, use the wire already connected to the speakers. You don't need any banana plugs or anything like that, unless you want to be able to easily disconnect the speakers. They're really not needed at all.
Angelmartin11
Martin Gomez
And what about this
Oh, i see. Also, another question xD. Would something like this work too?
JohnRice
A Mile High
And what about this
Absolutely. Any current surround sound receiver will work, as long as it has an optical digital audio input, which that one does.
JohnRice
A Mile High
...or an ARC hdmi input, but a lot of people find ARC to be pretty glitchy, and some don't. I prefer to avoid using it.
JohnRice
A Mile High
BTW, if you get a surround receiver, connect all your sources to it, NOT the TV, then run an hdmi cable from the receiver to the TV to get the video to the TV.
Angelmartin11
Martin Gomez
Ohh, then if i have multiple consoles and something like a roku, i can connect them all to the reciever and have only one cable going into the tv?
JohnRice
A Mile High
Yes! that is the best way to do it, and how systems using a surround receiver are intended to be connected. So, make certain the receiver you get has enough of the inputs you need. The one thing to remember, you have to turn on the receiver to get audio from any of the external sources (ex: anything that doesn't originate in the TV). I never understood why that would be a big deal. I have receivers on all my TVs and I turn them on with the TV. It's one button push, but some people will make things 10x more complicated and create all sorts of limitations solely so they can watch TV without turning on the receiver.
Angelmartin11
Martin Gomez
That sounds great!, I´ll save my pennies to buy one then. Thanks for the help!.
Josh.1983
