Hello Home Theater Experts,
We moved into a new home which has inbuilt roof and wall speaker system setup throughout the home. Here is the general setup.
Speakers:
1. Living area has 5 speakers in the roof (Front Left, Front Right, Front Center, Rear Left and Rear Right).
2. Living area has one subwoofer in the wall (not sure if this has one or two subwoofers in it).
3. There are 10 other speakers throughout the house (2 in each of four rooms and 2 in patio).
Devices:
1. Yamaha Receiver (RX-A2080 AVENTAGE 9.2-Channel AV Receiver with MusicCast)
2. Klipsch RSA-500 Subwoofer Amplifier
3. Sonance 6-Pair Stereo Speaker Selector
Here is the connectivity that is already there.
1. The cables for 5 speakers in living room are connected to the receiver and are working fine (through red and black wires), so no issues there.
2. The cables between receiver and speaker selector are already connected, so I am assuming they are connected properly.
Questions where I need guidance:
1. How do I connect the subwoofer? I have a cable running between receiver and amplifier already, but how do I connect the subwoofer speakers (wires from the wall outlet)? Should they be connected with amplifier? I have red black green white wire through the wall outlet which appears to be from subwoofer speakers (see right side highlighted on the attached image), but not sure how to connect these to amplifier? What kind of cable would I require and where would I connect this to amplifier?
2. The cables from speaker selector need to be connected to wall outlets. The wall outlets have only red and black plugs (see left side highlighted on the attached image). However, the cables from speaker selector have red black green white colors. How will this connection work? Is there a way to know which wall plug is for which room speaker if they are not marked?
Appreciate any help in this regard. Thank you.
Speakers:
Devices:
