WaltJohnson
- Aug 4, 2009
- walter Johnson
Please Help,
I've been collecting the pieces for our home theater/music system for the last year and now it is down to the subwoofer/amp before I start installing. I have put this system together on a tight budget off ebay (as you can probably tell from the equipment list below) The system is primarily going to be used for my two teenagers and their friends for televison/movies, xbox, and music (mp3s from a PC through an optical toslink cable).
Acoustics: The room is 12' by 23' with french doors and windows at each end. Of the remaining two walls, one is solid drywall since it faces the garage. The other wall faces the main portion of the house and has two doors. The wall that adjoins the garage will be the "rear" of the system and I plan on installing the subwoofer on this wall. Since it shares a wall with the garage, space is not an issue for the amplifier.
Current equipment (still in boxes) and how I believe they will be used:
A/V Receiver: Harmon Kardon AVR 635
Front Speakers: JBL Soundpoint SP6CII
Center Channel: Infinity ERSH V250
Surround Speakers: JBL Soundpoint SP6CII
Rear Speakers: JBL Soundpoint SP8CII
I'll be running 12 guage speaker wire for all the connections
I'll run RG6 with RCAs for the subwoofer amp connnection
Questions: I would like to stick with the in-wall configuration and install an in-wall passive sub with separate amplifier. I can only afford to purchase "pre-owned" equipment and have been looking at ebay to try to find compaible equipment. I have tried to do as much reasearch as possible but now need answers to some questions that may seem basic, but i just don't know.
Please help. Also, please offer suggestions if you feel I am doing something wrong with the equipment I currently have.
----Walt
- Should I be looking for a subwoofer in the 12" range powered by a 200 wall (or higher) amplifier?
- Many people are selling plate amplifiers for either DIY kits or that have been removed from free standing subwoofer boxes. Is there an advantage/disadvantage to using a standard subwoofer amplifier over a plate amp? What are the pros/cons of each?
- When looking at amps and passive subs, I see that the inpedanceofdifferent subwoofers can be either 4 ohm, 6 ohm, or 8 ohm. The amplifiers' WILL LIST 8 ohm and 4 ohm. This is the question that will make me sound stupid, but will any subwoofer amplifier run any subwoofer, or do you have to match them up based upon the Impedance rating of the subwoofer?
- I need to stay under $300 total for the amp and subwoofer. I've been looking at used Dayton, JBL, Velodyne, NHT, Eosone Polk, and M&K amplifiers. I've seen several of the Eosone Polk and M&K surplus plate amps lately on eBay. As far as subwoofers, I'm staying away from the low budget stuff and justing waiting it out for a higher quality used one to show up at a good price.
----Walt
