- Apr 23, 2000
- Alfer
We upgraded our laptop this weekend and all went fine. I logged into my Office account and Office 365 was loaded up fine. We have been using O365 on our retired laptop and Outlook runs like a charm, I have two email accounts loaded to it (POP accounts if that matters) and when we open Outlook (2016) we are presented with 1 inbox that pulls in BOTH our accounts emails. Just the way we like it to work.
We wanted/expected the same to happen when I installed O365 on new laptop. So I opened Outlook 2016 for first time on new laptop, it welcomed me, and started asking the usual set up question So I went thru, filled in all the email account info but I noticed it was setting it up as IMAP for both. Didn't think much of it until all was done and I went into Outlook and it turns out having a "merged" inbox isn't possible due to IMAP set up. So I figured I'd use old laptop and export the .pst file from it and load it to the new machine. Well it loaded, but still no merged folder, for that matter, the "All message" Inbox doesn't even populate with new emails. I have to look on the left Outlook pane for each persons email account and see if it shows having an email (noted by each name with a #..ex: [email protected] -2 )
My wife hates this, as do I and I want to get back to a single merged inbox like my other laptop using the same Office 365 does. I know it has something to do with using POP vs. IMAP which saves things as an ".os" file.
I read I can't just uninstall Outlook, I'm forced to uninstall ALL of Office 365 so I really want to do that, but fear that maybe Office 365 won't let me reinstall it all after I clean house. Meaning they may say I used up all my PC authorizations or whatever.
So, does of you Windows/Office pros know of a decent method to fix this? Is uninstalling best way and just start all over??
Any thoughts/ideas are much appreciated.
Other than this silly hiccup, we love the new laptop.
Thanks!
Thanks!
