Rnoodles
- Mar 9, 2011
- Ramon
Hey all, I'm starting to put together a home theater system that will be used about for about 40% music and 30% gaming and 30% movies. I've been doing a lot of research and debating with my self over exactly what I want and figured it would be best for me to go ahead and get started on a 3.1 and add 2 more speakers in the future. I'm open to suggestions or changes but this is what I've put put together after lurking these forums for a couple days and doing other research, but I really just needed some help narrowing down my choices. I'll mostly be using a my xbox and htpc.
Receiver: Onkyo 508
Sub: Either the BIC V1220 or BIC F12
I really havent been able to figure out any major differences aside from the front vs down firing. So any input would help.
The speakers is where I've been having the most trouble narrowing things down because I've been looking at everything from getting 2 bookshelfs and moving them to the rear in the future after getting 2 new fronts and a center. Or going and getting 2 floor standing and a center now. I've narrowed it down to 2 brands but I'm open to anything you guys might think would be a better direction to head in.
Polk: Center- CS 10 or CS20
Fronts/Rears- Monitor 40, Monitor 50, Tsi 100 or R150
Sony: Center- SS-CN5000
Front/Rears- SS-F6000 or SS-F7000 and SS-B3000
BIC: Center- DV62CLRS
Front/Rears- Venturi DV64 or DV62si
Any help between these choices or any new suggestions would be appreciated. Thanks!
Receiver: Onkyo 508
