Did it work previously for you? Often theres an option to turn off the display in your settings menu, did you check that? Its a long shot but did you try unplugging it for a minute, sometimes just a hard reset by unplugging will fix things....
If the display has just failed its unlikely its worth taking to a repair shop and/or may not even be repairable. Fully functional units can be found on ebay for around $100.
