Hi all ,
For aesthetic reasons we are again moving our living room around and are looking to upgrade to a 65 possibly 75" tv above the fireplace. The issue I have is my wife could listen to things through two tin cans and a piece of string and be happy, I on the other hand am a bit more particular and am always striving to get the best sound production I can from what we have.
In the proposed configuration I will be using all cambridge audio minx 21 and 22's to provide the primary 7 channels with at the moment 1 Cambridge Audio X300 sub with possibly an extra cheaper panasonic sub to balance things out.
The room dimensions in the proposed arrangement will be a width of approx 5m wide with a front to rear of around 3.5m ( setup was previously across the room so greater length and reduced width).
One of the problems I have is that the room is dual aspect and therefore has large windows in the middle of the left and right hand sides where I would normally place the right and left surround (middle speakers) and space behind the seating area is probably limited to around a couple of feet between the seating and a wall.
I had originally thought of mounting the surround and rear speakers just below ceiling level angled down towards the seating position however I have been advised that this will not work, that all the speakers should be the same height to provide optimum flow of sound around the room which I can see the logic of.
As it is not practical to place the side speakers on mounts in front of the windows I am seeking opinion on whether having side and rear speakers located at ceiling height ( approx 2m from the ground) angled down and in towards the seating area would provide decent surround sound if the front speakers were at a height of approx 1m from the ground.
If ceiling height was the only option for surrounds and rears would I get better sound by placing the front left and right speakers at the same ceiling height?
While I like to follow sound movement around the room I dont like to hear the sounds coming from the speaker placement if that makes sense, I do prefer just to be enveloped by the sound with no obvious speaker source which is why I rightly or wrongly thought mounting the side and rear speakers just below ceiling height would be acceptible.
Anyway the opinions of others would be appreciated, before it is suggested I dont want to return to just 5.1. I have experimented with this in the current setup and do feel there is a big improvement in sound and enjoyment in the 7.1 or 7.2 configuration.
Thanks in advance for any help and advice provided.
